I've been in the midst of decent sized project involving an inground shotcrete pool and surrounding patio/landscaping for the last 6 months. We dealt with a nightmare pool builder who constantly missed deadlines, went AWOL for weeks at a time, and finally we found out he ran out of money and we were able to terminate him and bring in a new pool builder to finish the job.
Our new pool builder is concerned because the walls on the pool where they meet the floor are all at 90 degree angles (see photos attached), and have no radius built into them. The engineered drawings showed a 6" radius in the shallow end and a 9" radius in the deep end. The pool is 18'x46' rectangle with an 8' tanning shelf and depth goes from 3'6" to 6'6".
As far as I could tell, the construction of the pool was done well and there was plenty of rebar. But the other concern the new pool builder has is that they shot the pool in 2 days, first they did the bottom and then they shot the walls. So there is a cold joint at the base of the walls, although I've read with shotcrete that a cold joint should not be an issue.
Should I be concerned with that sharp of an angle on the walls? Can we add in a radius to solve this or are we facing a massive fix (i.e. chipping out walls and reinforcing back into the existing rebar, etc)?
