I'm just curious how many others do or don't have a separate grounding rod installed at their pool equipment subpanel. Our pool was built last year and does not have a separate grounding rod, only the equipment ground running in the underground PVC conduit back to the main panel. Our inspector apparently did not require a separate grounding rod, because our pool passed.
The reason I am asking: From my reading on the Mike Holt website, any time a subpanel is installed detached from the main structure, it is considered a remote subpanel and the NEC apparently requires dedicated grounding rod(s) in addition to the equipment ground running back to the service entrance. This even includes panels that are mounted 12 inches away from the main structure on a separate post, as ours is, as the post is detached from the main structure and technically deemed a separate "structure."
I'm curious if these (well intentioned) code guys are "all wet" in terms of actual industry practice, or if my pool needs an upgrade.
