Thanks for the help with my other posts already!
So, I put in a new motor, replaced all o-rings and main seal, also installed new impeller yet after I hooked the pump back up I saw water dripping out of the slot below the impeller main seal area.
I removed pump again and put it on a table and filled up the basket with water and I can see the drip in that spot.
I disassembled the impeller and check the new main seal and it looked good but had a spare new main seal and lubed and pushed the new one in ensuring it was fully pushed in and level with a small piece of cardboard etc. reassembled impeller and put everything together and bolted it all up again on table.
Filled basket with water and waited, can still see a drop or two after a while.
So other than the main seal having something wrong with it or that area, what can cause water to infiltrate that specific portion behind the impeller area?
Any ideas?
Any ideas?
