- Dec 13, 2018
- 443
- Vinyl
- Pentair Intellichlor IC-60
Hello all,
Looking for some advice and confirmation I am doing this right.
When we built our pool we had 2 deck jets installed on each corner with the intention of installing bowls in the future. Future is here and we are installing.
I have my pipes extended up and am about to install bowls. I plan to just use a hydraulic cement in the hole around the PVC pipe. Is this ok?
Would you bed the bowls in with mortar? I don’t want to mess up the travertine in case we ever remove them. The bowls weigh about 100 lbs.
Also, I had to tweak the location of the pipe, so now the paver hole does not line up. Since this is hidden, just leave the paver out and fill with sand or cut in a new one?
Thanks.
Thanks.
