Thanks Marty and Dirk. Looks like I'm going to to stay late again reading TFP
My wife woke up a few nights ago around 2am, saw me reading the TFP page on my phone in the bed and... "it can't be so interesting!" haha. OK, so I will know more tomorrow, at this point I will trust you.
Well, I already decided to trust you and I'm almost there since I started all changes a few days ago. I hope I will not have any issues by following the "Taylor" Langelier index for last two months. It does a bit different math. It was obvious to me it is important and nothing changed except now I'm changing the whole chemistry to the TFP recommendations. I think I was slightly smarted than you, or lucky. I had my pebble installed middle of June so it is about 2 months now. Not having the best opinion about pool service companies I decided to take care of the start up myself from the beginning because I love my new pool
Ordered the test kit and started monitoring and maintaining everything everyday, researching subject in the meantime. I do not believe any guy for $100-$500 would provide me that level of service. I saved money, learned a lot and I think I'm on the good path to have a trouble free pool. Right, it is not going to be maintenance free
As you know from another thread I decided to buy and use acid dispenser (set to 100%) because I had to dump so much acid regularly and... in last two days when I started raising my CYA I ended up with turning it off and changing SWG from 85% to 15%. Right now I'm in a bit strange situation (2 days so far).
FC 5.6
pH 7.4
TA 80
CA 375
CYA 60
Temp 83
That results with CSI = -0.33. If I raise pH to 7.8 I will be set on 0.05, however my pH is so crazy stable now that it doesn't want to go up haha. Anyway, I still have my socks with CYA in the skimmer running for another 24hrs so tomorrow my CYA will be around 75 and... this is what worries me. My CSI will be even more acidic ~0.37, if I can call it that way. I think I need to figure out how to bump up the pH. I directed returns toward the surface (I installed Venturi returns) to create a bit of bubbling, turned the waterfall on, and the spa spillover. I read that aeration can help me to achieve it without any additional chemicals. It is not really changing so far.
