Hey all! I'm new to this forum and I need some help.
My wife and I purchased a home back in December that had (and still does) a 20,000 gallon in ground pool. I had to put in a new Hayward 1 HP pump in because the old one was shot. Anyway, let me get to the point. We keep getting sand on the bottom of our pool!
When I first noticed this issue, I vacuumed the sand up on the FILTER setting on my sand filter. After about 10 mins, I noticed all the nasty debris shooting right back out from the return jets. I then read online that I should vacuum this sand/dirt on the waste setting. That's exactly what I did. Vacuumed the sand on the waste setting. I even did a nice long backwash and rinse to make sure nothing would get back into the pool. The pool was looking sparking clean the next morning. My wife even went for a swim! However, later in the day we noticed the sand was coming back and settling on the bottom of the floor again!
So, I went online and I was reading about broken laterals and old sand and all that. Since I had no idea how old the sand or laterals were in my filter, I decided to change them out yesterday. Brand new sand - 250 lbs. I got that amount from my filter manual so I'm 100% sure that I put the right amount of sand in. I also put in a brand new lateral assembly. I taped the stand pipe, and cushioned the filter halfway full of water before adding the sand. There's no way I broke anything while doing this. I followed a step by step instructional video online and completed the entire process without any issues. Anyway, I backwashed right after putting the filter back together. Gave it a rinse after that. Then, I vacuumed the sand out of my pool to waste AGAIN. Once I was done vacuuming, I turned the pump off and put the filter into the filter setting. Jets running great, PSI at 10. Everything looked good.
A few hours later, I noticed the sand appearing on the floor of my pool again. Seems like the sand was in the same spots as before I vacuumed. Most of it as on the ridge where the shallow end starts to dip off into the deep end. I figured there may be some settled sand from vacuuming too fast (I was afraid to lose too much water), but there was WAY more sand than I thought would have settled.
I have absolutely NO idea what's causing this. Does anyone have any idea?
Joe =)
Joe =)
