Salt question
mfitch
2
Texas
I have had pools with a Salt Water Chlorine Generator for 30 years in NJ. Only downside is getting about 12 40lbs bags of pool salt every year from Walmart for my pool opening. Once the salt is in the pool and the SWCG is generating chlorine there is little to do other then check the water chemistry weekly, confirm the cell is still generating, and tweak the % generation as the season changes.
You will find a good comparison of SWCG products at...
Lots of folks here like the Circupool products.
I thought the salt essentially stays in the pool, broken down to chlorine and sodium that recombines to sodium chloride. Why do you need to add that much salt every year?
Welcome to TFP.
My pool is closed for the winter and water level drained down at closing. That dumps salt, CYA, and CH out with the water.
I just checked my recently opened pool and I need 10 bags, 400 lbs, to raise my salt level back to 3600 ppm. At opening it was 2200 ppm.
1/3 of the water was lost in the winter closing and pool opening vacuuming.
Reactions: Mdragger88
Welcome to TFP.
Thanks for the explanation!
