RV Macerator Pump 12V 12GMP, RV Waste Pump with Garden Hose Discharge Port, Quick Release Sewage Pump as pool pump?
primuspaul
184
NYC area
Can this item be hooked up to my sand filter and work as a pool pump? I realize I will need some sort of 240/120v to 12v adapter. Only asking because I have the opportunity to get this item for free. Current pump works, but I like to have a backup. Considering getting this and swapping out current pump to keep as a backup and use this waste pump for general duty until it dies and then I replace with the used pump I will have put into storage.
Current setup:
I doubt it would have anywhere near the power to move a large quantity of water over a long time period.
It "may" work sufficiently good enough to act as a sump pump to lower the pool water level for closing.
Current setup:
No. Not a self priming pump. 12 GPM? Dirt would fill the pool before it would be filtered. Would not shove water through a filter. Etc, etc,etc,.
Reactions: primuspaul
