Hello folks. Boy do we have a problem! Had a bunch of white scale on the rocks at the waterline and scrubbed them with a wire brush. It worked pretty good. Didn't realize a whole bunch of the little metal wires fell off of the brush and sat in the water and created a whole bunch of stains. By the time we figured out what it was, many more marks appeared mostly on the bottom of the pool. The Kreepy Krawler didn't pick them up, just moved them around the bottom of the pool creating more rust stains. There are several hundred marks about an inch long totally scattered. It is a medium dark blue plaster. I scrubbed a couple spots with scotch brite and it lightened the plaster and still left the rust spot. Tried some absorbic acid today and it worked fairly good but didn't completely remove a few. We have used Leslie Pool's Ultimate Scale and Stain Remover but the bottle states it takes 2 to 4 weeks to work. Any ideas? Thanks for any advise
Bev
