I had an odd thought. I have an Intex 1500 gph filter/pump combo. Since my filter isn't doing a good enough job I've ordered a new sand filter. In the meantime, can I hook up my 800 gph filter/pump to the 1500 gph filter/pump so the water will go through two filters before entering back in the pool? I'm thinking of running the outflow from the pool into the 800 and running the return line from the 800 into the 1500 and then the return line from the 1500 back into the pool. I'm thinking of only running the 1500 pump and not turning the power on the 800. Or should I run both? Any thoughts? Crazy idea???
The reason I'm wondering if it will help with filtering is because I stuck a filter on the pipe I rigged on the return in the pool so the return water would flow through the filter. I checked it tonight and that filter is DIRTY!
