Rubbing Black Algae With Chlorinator Tablets
jgf310
0
Jul 30, 2016
63
Connecticut
In a couple threads I have seen people mention that eradication of black algae can be helped by rubbing it with chlorinator or skimmer chlorine tablets.
My black algae is under about 8 feet of water...
what's the best way to do this?
I was thinking I could come up with a way to attach a tablet to the end of the pole for my brush.., but I thought that probably someone has already figured out the best solution.
How are most people doing this?
Reactions: jbrinks
I managed to rub my black algae with a puck.
How long does it take to see a difference?
Is it minutes, hours, days...
if it isn't gone, how long should i wait till i go over it again?
Or, do you just keep rubbing til it's all gone?
thanks
If it's black algae you should see a difference within 24 hrs or less. Sometimes you will have to to go over it several times. If this a large area of algae you may want to try a granular trichlor and broadcast right on to the area. Keep pump off and wait for what for water to settle
