- May 20, 2021
- 45
- Vinyl
- CircuPool RJ-45
How can I check salt levels with RJ45? It has a salt inity button and under menu salt level. Does the chlorine generator need to be generating chlorine to get a reading? Can I turn on unit but set power to zero and use the salt inity button to read level?
Reason I ask is salt inity button says 2600 but turn on chlorine generator to 5 percent or more then menu salt level reads 600 confused new owner. Need help. If I turn on generator 5 percent or more runs 10 min then says low dalt and clean cell same time. Salt inity stays at 2600, was 3700 when first hooked up.
Thanks
Thanks
