I got a Riptide XP pool vacuum cleaners, and WOW, 65k-68K, no problem. This equipment, along with a skimlite 6317 pool pole, will clean this size pull up in no time. It sucks up dirt and debris like nobody's business; you just steer it and not try to fight it. This thing will blow every automatic pool robot out of the water in the category of cleaning . . . the robotics are Tonka toys compared to this commercial grade equipment. I have a Dolphin s400, and that thing is as dumb as a door knob; the debris basket is tiny. Most of the time, the Dolphin can't even suck up oak leaves. Riptide, on the other hand, will suck up anything, even thin slate layers that fall into the pool bottom. For about ~$1000, it's is really worth it.
Downsides and Tips:
The debris bags is tough to put on and take off. Removing the bag is very difficult especially in cooler or cold weather. They have a tool to help, but a blunt flathead screw driver could help. Get the lifepo4 battery under $100. It is less than 10 lbs. The cable and connector are very heavy duty. You'll need to put some muscles to get it connected. This is commercial quality material and handling. You need a professional pool pole. Steering the riptide is done with twisting the pool pole. Hence, I got the Skimlite 6317 with quick snap to extend and retract. Once you turn on the riptide, you better get ready to steer because the thing will move itself. I find that taking it out of the pool while it is running is difficult because of the suction.
Suggestions:
I think that if Riptide made a "junior "riptide XP", it will sell to DIYer like hotcakes. I have step treads that are 16", 24" and 48" deep, so a 18" wide riptide would be perfect. Also, my steps and shallow areas are only 6" depth. A small riptide could take care of vacuuming shallow areas as well. These Riptide equipment are built to clean junior and Olympic size pools. They need make one for the residential crowds.
Summary: If you have a large pool and tired of incompetent robotic vacuums (pool bottoms), the Riptide will do the job. The robots and pool side pressure cleaners are good for maybe <30K gallon pools. Getting a riptide or similar equipment is really a Eureka moment assuming you have some muscles and some times for cleaning. It is very satisfying when you use the right equipment for the job.
Downsides and Tips:
Suggestions:
