Rheem Heater Sensor Failure
Yes it would be the temp sensor and easy to replace. Remove the front panel, unscrew the four screws holding the front bezel in place. Now you have access to where the sensor plugs in. Remove the side panels where the water pipes are at. With the pump off, you will see the white nut that holds the sensor in place. Unscrew, remove, remove wire from board. Reverse the process to install the new sensor.
