I'm sure the neighbors must talk about our gurlgle noise. I don't like it much myself. This is the constant scenario:
Water comes out of the return into the pool (eyeball aimed mid way down and to the side.) I have good flow, pump is working well, skimmer is doing it's job. slowly a little vortex forms above the eye return into the pool....it slowly lenghthen until it makes connection with the return stream, then GRRRRRRR, the horrendous gurgle type noise fills the neighborhood for a few seconds and stops. REPEAT a bazillion times a day.
What is the solution? Aim the eyeball further up to ripple the water surface? Doesn't it need to aim down for proper flow?
My neighbors thank you in advance for a solution
