Hello everyone. Im not sure if this is the right place to post this so if not please direct me to the appropriate area. With that being said, let me dive in (pun intended)
I have an in-ground pool approx. 7000 gallons. (kidney shaped) I live in SW Florida so I know the water table plays a big role in pools popping out of the ground. It has been a couple months since it has rained here. We are in our dry season. My pool is looking very bad. The previouus owners "doctored up" the pool to make it look good. What happens is when you get in the pool and play around a while all is good until you get out. THats when you notice that the bottom of your feet look lite a smurfs! Apparently they did not use enough of the top coat. Now I have many areas with white showing through where it should be blue. So let me get to my main question...
I am planning on repainting the pool but I am worried about the pool "popping " out of the ground. As I am a first time homeowner and first time pool owner, what do I need to do to prepare?
