The clock does not keep proper time.
A thread on this board repair can be found at Hayward ECommand not keeping time: updated DIY repair guide.
You can replace the board or try repairing the board.
On the board it has a capacitor on the left top corner, it's like a double battery in wrap.
You can buy on Ebay for about $3 and 5 mins to replace it.
After replacement you run for 1 hr it will charge the battery.[8]
On the board:
U1-Microprocessor is PIC18F2620 (28 pin version).
U2-Real Time Clock is Dallas / Maxim RTC is $3.50 at Digikey (DS1302Z+CT-ND)
C3-Super Cap is 5v and .33UF Digi-Key KR-5R5V334-R
X2-is a 32.768 kHz Crystal Epson MC-306 / 6 pF (SER4099CT-ND at Digikey) and costs $.046
Some people replaced just the C3 capacitor, others replaced C3 and X2, and others replaced U2, X2 and C3.[9]
Replacing U2 and X2 is not an easy soldering job if you are not used to surface mount parts, don't try it.
After replacing parts you need to wait about 24 hours for the real time clock to start working and then adjusting it to current time.
For the 4th time in 12 years, the main control board on my Hayward pool system went out (the board is Hayward GLX-PCB-MAIN). Each time the board lasts 2.5 - 3 years so it is out of warranty. Each time the symptoms have been the clock not keeping time and as a result, the pool cycle starts at a...
www.troublefreepool.com
The time setting on my aqualogic control panel keeps changing It's hard to get the pumps to run at the right time when the time keeps changing any ideas?
Prologic Controller has been losing time for a week and finally stopped all together. I've checked what I can with multimeter. Supercap C3 for power outage seems to charge up. Voltage (approx. 5VDC) on the U2 time clock chip when controller is powered. Time Display has 1 second blinking (Colon)...
