The air release valve on my Pentair FNS Plus 48 sf pump has started dripping in the closed position. From reading this helpful forum, I think it's likely the o-rings need to be replaced. Before I unscrew the air release valve to inspect, let me ask what may be a stupid question. My pool equipment is below the pool level, so I have to close a Jandy valve right before the pump when I clean out the pump basket (otherwise water pours out at a high rate). Do I need to close this Jandy valve before I unscrew this air release valve? Is the filter tank full of water since all the equipment is below the pool level? Do I need to drain it out or anything? I just want to know what to expect when I unscrew this air release valve. Thanks in advance for any advice!
