We have had 3 pool companies come to our home to check out our 30 year old pool & give us an estimate to refinish/renovate. We have 3 separate answers from the as for choices on how to do this. #1. Says since we have a ton of tile we could keep that & they would acid wash to soften then remove grout from tiles, regrout & then put a finish in the pool that would be an aggregate. #2. Says tile needs to be replaced then they would refinish rest of pool with aggregate. #3 Says they would lay tile directly on the existing tile & go over the finish with a new aggregate. If a tile is loose or comes loose during the process they would just re do that area to the thickness of the other tiles. They all talk about 'soft spots' so we are prepared for this event.
My question is this; 1. There are existing stains on the finish at this time. If they don't remove the old finish completely will it eventually come through?; 2. If they install the tile over existing tile, if the old tile for some reason begins to lose its ability to stay put what happens then? New & old tile have to be removed & redone? We thought getting 3 quotes was reasonable to help us decide which to do, but they all have different processes & ideas as to how to completely renovate. We are a bit confused now. Can you help. This is not a cheap procedure any of the options provide so we are willing to invest but would like to make the best decision.
Thank you.
Thank you.
