We are remodeling a 1964 or so lazy "L" shaped gunite in ground pool.
My Questions:
Existing Pool Specs: (Please see photos also).
Proposed remodeling selections: Approximately $30,000.00
Thank you for your time and I appreciate your advice and recommendations,
Scott
Photos will be added in post below:
My Questions:
- What brand and model automation systems are best? I have new Pentair IntelliFlo VS 3 HP 230V pump, plan to have solar heat panels, plan to have SWCG and two 12V color LED pool lights.
- Should I plug up and fill in old main drain? (it has a copper pipe to old skimmer I am concerned about)
- What type, brand and size filter is best?
- What brand and size SWCG for my pool?
- What brand LED low 12V lights to use here with old stainless niches?
- Approx 35,000 gallons, 122’ linear perimeter, approx 756 square feet surface area.
- 1 skimmer with 1.5-inch copper suction line and main drain connection and two 1.5” return lines, one shallow end and one deep end.
- Maytronics Dolphin M4 robotic cleaner (4 years old).
- Small swim out in deep end.
- Three steps in shallow end with long extended middle step.
- Two non-functioning lights (power has been disabled) one in deep end and one in shallow.
- Drain & Strip pool to 80% gunite. $3,940.00
- Adams Pebble Plus standard colors (Has Glass beads mixed in) $7,795.00
- Remove tile and Install New Customer Supplied 6”x6” NPT Tile. $2,360.00
- Remove coping and install New Customer Supplied concrete coping. $4,812.00
- Install 2 steel rebar forms for 2 deep end swim out seats. $3,950.00
- Re Plumb Pool: $4,125.00
- New waterway skimmer
- 2 ½” suction line
- 2” return line reduced (split) into qty 4 1 ½” return lines with 1 fittings at pool shell. Non-threaded fittings.
- 1 ½" vacuum line with valve.
- Auto Fill $750.00
- Install Qty2 new red brass conduit for pool lights $990.00
- Install new concrete 4’ x 8’ equipment pad $550.00
- Install all homeowner suppled equipment $0.00
Scott
