Recommend Replacement for Sta-Rite IntelliPro 4X160 Pump
Aug 4, 2008
47
I've had the pump since the pool was built in 2008. It runs 365 days a year for several hours a day. It's still working fine but based on the lifespan of the pool's feature pumps (a 2HP and a 1.5HP max-e-pro which have had shaft seal and motor bearing failures). I want to start researching options now so I'm ready when the time comes.
The pump is controlled by a Pentair EasyTouch 8 system (with the latest firmware).
Ideally, I'd want something with the same plumbing profile to avoid replumbing but if avoiding replumbing means I have to compromise quality, I'd consider replumbing.
Looking forward to your recommendations.
Reactions: geobrick
All of our content is free of advertisements.
Please consider donating at:
The IntelliFloXF VSF Pump sits a little bit lower, which is easy enough to lift using a base of some type.
The difference is about 1.7".
Thanks. Great information. They seem closer than 1.7" based on your images and the pdf docs. The outlet plumbing is easier to modify if needed.
Does Pentair make direct retrofit?
Reactions: JamesW
Looks like it was discontinued.
Why not replace the motor only on the other pumps? The Century EVQ variable-speed motor would fit the Sta-Rite wet end and can be controlled by the Easy Touch as variable-speed pumps.
The wet ends last "forever" unless damaged some way externally. Seal failure is vey rare, though they do wear out regardless if the pump is new or a motor is replaced.
Seal damage is virtually always a result of a pump running dry.
