I just purchased a 24' x 54' round pool that I will use for a saltwater setup.
I know I want to do a cartridge filter. I will be a first time pool owner. My search on the internet shows this is approximately 15,000 gallons of water and the rule of thumb is 100 sq ft of filter surface per 10,000 gallons of pool water as a minimum.
The recommended filter where I purchased the pool from has the Hayward XStream 150 Cartridge Filter System 1.5-HP Power-Flo Pump which I see is 150sq ft.
I see bigger is better and recommended sq ft for my size pool is 200-225.
So I have searched up some cartridge filters that fit in that 200-225sq ft range.
I have found Pentair - EC-160353 Clean & Clear RP 200 sq. ft. and the Hayward SwimClear Multi-Element Cartridge Filter 225 Sq.Ft.
Are there any other recommended filters I should look into purchasing? Or did I find the two best options?
