- Jul 15, 2012
- 628
- Plaster
- Hayward Aqua Rite (T-15)
My spa heater got a sensor failure error last week. I cleared it by shutting unit off and on. Same issue 2 days later and same fix. 3 more days later it is stuck at sensor failure and cycling power does not reset.
Its gotten colder and issue started when spa water was below 65 degree. Down to 62 today when cant clear error. Only reason I am concerned that it may be something other than just needing a replacement sensor is that the water temperature reading at 62 degrees is correct. If sensor fails, how does unit know water temp?
