Rat-proofing a Hot Tub ?
marcgr
0
119
Austin, TX
I just got a new Vita spa. I live next to a greenbelt and I had rat problems in my old spa. The sales guy told me the new Vita was rat proof and I believed him… well there’s about 1/2” gaps all around the bottom which are definitely not rat proof.
What do y’all recommend for rat proofing? Stuff the gaps with steel wool? Use rodent-proofing foam, and would it void the warranty? Try to custom-cut plastic or metal to fill the gaps? Something else?
I already have a dog and a cat and I still had rats in the old tub equipment. I found a big snake skin shed in the old one before too so even the snakes aren’t getting them all.
Check with your dealer, they may be necessary for venting.
Moth balls or dryer sheets will discourage critters from nesting in there.
No spa is critter-proof as they can chew through just about anything if they want to. I had a customer "cover a hole" and end up with 4 figures worth of damage from a trapped squirrel, who wound up chewing through the metal flex conduit on the main power feed and adjacent 2x4 to get out.
  • Wow
Reactions: bpardy and JamesW
Would half a pool puck in there put enough chlorine gas in there to make it less hospitable ?
Would the chlorine also aggravate the control panel ? (not sure).
12 Smells that Mice and Rats Hate (#1 is Unbelievable) is a Youtube video.​
Peppermint Mice hate the smell of peppermint and will avoid areas where it’s used. Many natural rodent repellents contain peppermint oil because the strong scent irritates rodents’ nostrils. Vinegar This homemade mouse repellent contains acetic acid, a scent that mice are highly sensitive to. Once you've located droppings and feces of rats and mice, you'll know which areas they visit often. Another way to get rid of rats using vinegar at home is to soak cotton balls in vinegar and put them in the places where they appear. Chilli power Chilli powder, chilli oil, and hot sauce in general are among the odors that mice hate. This is because chili contains Capsaicin, a natural compound that irritates mucous membranes and eyes. Ammonia and Chlorine Ammonia and Chlorine are very common chemicals in the home as they are found in various cleaning products such as window and glass cleaners, disinfect sprays, laundry detergents, dishwashing detergents, bleach, and all-purpose cleaners. Even though these chemicals have a strong smell that can be tough for us, it's way worse for mice. Breathing in these smells or eating products with these chemicals can seriously harm a mouse. So, it's important to keep these products away from your pet mice. Mothballs Mothballs are small balls of chemical pesticide made of Naphthalene. They have a pungent odor which is why they are commonly used as a moth repellent. Mothballs are harmful to humans if swallowed, or if large amounts of fumes are inhaled .Although Mothballs can be harmful to your pet mice, they aren't powerful enough to get rid of unwanted mice and rodents in your home. Citrus Another scent that mice hate is citrus. Mice do not like the smell of citrus oils and will avoid areas where they smell them. Citrus oils are frequently used as a natural repellent for mice or rats. You can make your own homemade mouse repellent using essential oils like orange or lemon oil. Predators Scent As tiny rodents, mice and rats are vulnerable to many predators in the wild. Owls, hawks, snakes, lizards, dogs, foxes, and cats. Due to their vulnerability, mice have learned to smell their enemies and avoid areas where these predators are present. One way they detect the presence of predators is through the scent trails left by their urine. If you live with rats or mice, along with other pets like cats or dogs, we recommend ensuring they are separated from any areas their urine may be present, and that they are cleaned with enzymatic products. Cinnamon. Cinnamon is another natural repellent that mice hate. If you have unwanted rats or mice in your home, you can sprinkle cinnamon powder around your home or burn cinnamon incense. You can also stash some cinnamon sticks in drawers, closets, cabinets, and underneath furniture. Perfume and alcohol Perfumes are made with different components, among which are distillates of essential oils from plants and alcohol .They often contain sulfur and other inorganic compounds. Perfumes have different aromas that are pleasant for humans but intolerable for many animals including rats and mice .In small rodents such as mice, irritation of the nasal passages is a common reaction so they prefer to stay away from these odors. Eucalyptus oil A great deterrent for not only mice but insects too. Eucalyptus oil has been proven to have strong repellent effects against rodents. It can significantly reduce the likelihood of an infestation when applied around the house. Onions We all have garlic and onions in our homes, and such smells are repulsive to mice and rats. You can chop up an onion and place it in areas where you see evidence of mice, such as droppings or nests. The smell will keep them away from the area where it has been placed. Lavender Mice hate the smell of lavender. You can use a lavender-scented spray or even better, you can grow a lavender plant, which will repel mice from your home naturally. Certain sounds In addition to these scents, rats and mice are known to be sensitive to specific sounds. There is evidence to suggest that certain types of high-frequency sound can be effective in deterring rats and mice. Rodents have a broader range of hearing, and these sounds cause distress to them.
