I've read it is best to leave this chlorinator's adjustment wide open while only putting a single weeks supply of tabs in at a time. Is this true? I have to replace the lower valve every two or three months when set on lower opening, 1-2.
The feeder valve which gets clogged with paste. Since we are in the Phoenix area about everyone I know are on the 2 year and out water plan due to the water content. If you don't dump your water every 2 years you have great difficulty in keeping chemicals in balance. Cyanuric Acid and Hardness goes out of sight. Not sure if switching to liquid chlorine would help or not.
I'm down in Tucson. I have an SWG pool and the only chemical I added regularly is acid to control pH. I typically need to add CYA once per year. My water is going on 4+ years old and my CH is 1250ppm. My pool is uncovered and is subject to natural evaporation and fill. My fill water is typically 250+ ppm CH. I will probably dump my pool water soon or wait until the spring but I have minimal to no scaling issues. If I had softened water plumbed to my pool fill line, I'd probably be at less than half what my current CH is.
When you follow the TFP Method of pool care, and if you can make simple adjustments to how you fill your pool, there's absolutely no need to dump water every 2 years. Dumping that frequently is simply a consequence of indiscriminate use of pool chemicals that load up your water with excess CYA and CH. There are folks on this forum from AZ that have pools with water in them that are 5-10 years along without ever having to dump the pool or do any significant draining.
You can do much better than you are now if you choose to follow the methods taught here...
Chemicals I use are Pool Perfect Phos Plus, Muratic Acid, And Scaletec along with Leslie's CL tabs. Maybe Leslie is a little overboard on water analysis. I usually do my own with Taylor reagents, but still have Leslie check every few months.
They suggest hardness 200-400 mine is 460; CYA 30-99 mine is 120; TDS less than 2500 mine is 2800; Phos not bad at 200. I put a montly maintenance dose of Scaetec in. If I raise the water level calcium deposits disappear and the reappear in about 2 weeks when water level is brought back down.
If I don't change water this winter the chemical balance would be hard to maintain in the heat of next summer. We also have solar heating keeping water temp around 90 when possible.
Have a read through these two links and then let us know if you'd like to try TFPC. You'll never look back if you do
TFPC for Beginners
In a nutshell, you'll need to drain/refill around 1/3 to 1/2 of your water to get the CYA in check, and then should be good (water wise) using TFPC for several years. Half the chemicals you mentioned will not be needed, your pool will sparkle, and you'll know that it's actually safe for your family and friends![]()
You have been a member here for two years, so to be blunt....Essentially I think I'm pretty much following the TFPC program.
I can understand that a SWG would be nice. I would like to avoid the additional cost if I can. I may switch to liquid CL after dumping pool this winter. Only issue is management of periods away from home. We are retired and do travel. Is it inherently bad to dump a pool? When I checked it cost less than $10 to refill my 13,500 gals.
Test Hardness & Cy Acid with test strips.
If you are adding tabs I would really recommend testing CYA with taylor or tf100 test kit. If your CYA is off (by the regular margin of error seen with test strips)you can't possibly hit the right FC/CYA and know when to dump water.
@$10 per 13,000 gallons of water wow! I wish I had that rate. I would think if you started a combination of liquid chlorine + tabs using a full testkit and no more strips you could probably manage (and have to replace water much less often). Don't let your CYA get too high, certainly not over 100. A SWG is my favorite option if you can swing it.
A recent test from Leslie's shows 150 which I'm inclined to trust.
I tested CYA with Taylor kit but it basically isn't exact over 100. A recent test from Leslie's shows 150 which I'm inclined to trust. Plus solids are 650 which I also believe. I get calcium on tile (not bad) which goes away when water level is increased to cover (Scaletec)
