Hello. New spa owner who has been having quite a few problems with water chemistry. Mostly due to my own lack of knowledge from the beginning, but I've done a lot of reading and I think I know what direction I need to be headed in. I have been using test strips so these figures are not precise. I do have a Taylor K-2006 drop test kit on the way that I will use after draining and refilling the spa.
Water is running through a softener. Tested both a bathroom faucet and the outside spigot that is being used to fill the spa with test strips. Outside spigot has been tested with and without a pre-filter.
Spa: Bueno Spa Jersey Hot Tub
Water Capacity: Manual states minimum water is 1136 liter or approx. 300 gallons (should I use 300 in the PoolMath Calculator or up it to 325?)
CH: 0-? (very low)
CYA: 0
TA: 180-240
pH: 8.4-8.8
After asking some questions at a spa store, I was told to use dry acid (Clorox pH down) to bring down the pH and the TA would follow. Nothing was asked or mentioned about calcium hardness. This may have eventually worked, but I was following the directions on the dry acid container and when I compare that to the PoolMath Calculator, I don't believe I was adding nearly enough dry acid. I was adding 1.5-3 tsp at a time and the pH wasn't budging. The PoolMath Calculator suggests with a pH of 8.8 and TA at 240, I would need to add 2.7 oz by volume or 16.2 tsp of dry acid to bring the pH down to 7.0 from 8.8. (Am I thinking about all of this correctly?) Moving forward I will measure everything by weight for accuracy.
I did eventually get my pH down to 7.2 and TA down to 40-50 ppm by using a product called Acid Magic (tested with strips and calibrated digital pH tester). The container stated to use it exactly as you would use 31.45% - 20 Baume muriatic acid, but I had to use way more of this product than what the PoolMath Calculator suggested for regular muriatic acid of the same strength. (Possibly due to starting out with TA at 180 - 240 ppm?) After a few days my water became very cloudy and while I believe it to be due to the chlorine levels or lack thereof, I think the best thing to do is start over with a fresh fill. There are other things that I have attempted, but I won't get into it, because it only adds chaos and confusion to a situation that already has too much of both.
I'm going to drain my spa once more and start over using what I have learned from Nitro, but I do have a few questions. I'll run through each step of the process in the order that I plan to tackle the issues and ask my questions. I'll highlight my questions in red, so they are easier to spot. I've read the post 20+ times over the past week in an effort to completely understand the process and formulate the questions that I still have.
1) Fill spa with soft water and heat to 95F (Is 95F sufficient? Nitro mentions near 100F, how does the water temp affect this process?)
2) Test CH and add Calcium Chloride to bring up to 130-150 ppm (If I'm going from 0-50 to 150 ppm, how long should I wait before I retest? Can all of the Calcium Chloride be added in one shot?)
3) Test pH and TA
4) Input current levels into PoolMath Calculator, set destired pH to 7 and desired TA to 50 ppm
5) Turn on jets, air, blowers, waterfalls ... Add enough acid to bring pH to 7. Aerate until pH is 7.8 again (30 minutes).
6) Add more acid and repeat until TA is at 50 ppm (Each time that this is repeated, should I be adding enough acid to bring the pH down to 7 based on the current pH reading, up until the point at which the TA is at 50 ppm?) (This is the part that I am not clear on. The summary says it takes 8oz of dry acid to lower TA by 100 ppm and don't add it all at once. How much dry acid by weight is safe to use at once? And we're talking adding X oz, aerating for 30 minutes, and repeating? And this process can be stopped when the TA is at 50 ppm?) (I am very confused by the statement add enough acid to bring pH to 7, but then in the summary, don't add it all at once.)
7) Add borates. I'll be using Gentle Spa (Amazon.com) (Nitro post says ideal amount is 50 ppm (I don't think the K-2006 drop test kit will test borates), how do I measure this? Should I use "borax" in the PoolMath Calculator? That would suggest 19oz by weight for 325 gallons.)
And on to Sanitation ....
1) Shock to 10 ppm FC with Dichlor
2) Continue monitoring FC level on a daily basis and adding Dichlor until you have added 34 ppm, which will put you at 30 CYA
3) Daily additions of Dichlor are based on daily measured FC vs desired FC of 6 ppm
4) Switch to bleach after 34 ppm of Dichlor has been added
I think the rest will be monitoring FC based on spa usage. I may have some additional questions regarding the use of MPS, but I want to get a good grip on FC levels for 1-2 people using the spa 2-3 times per week first.
Thank you in advance to anyone who takes the time to read though all of this madness and comment on it. I have had my spa for nearly two months now. I have drained and refilled it 4 times. Each time I have learned a bit more and gotten closer to a successful end result, but I'm just not quite there yet.
If it comes easy, was it really worth it?
CH: 0-? (very low)
CYA: 0
TA: 180-240
pH: 8.4-8.8
3) Test pH and TA
