This summer the price of chlorine finally pushed me into making the switch to a SWG (CircuPool RJ-60 PLUS) and I knew it would be a smart move but I had no idea how great a decision it would be. I read a lot of articles here about CYA and settled around 70 and my FC was always between 6.0 & 7.0. The water was crystal clear all summer long, so thanks as always for all of the detailed information and guidance.
I just closed my pool and looking back on the summer, I have a few quick questions that I hope are easily answered by the experts here, thanks in advance.
- Lines are blown out and no water visible in the SWG, anything else to do for the winter? Would prefer to leave the SWG installed if there’s no appreciable benefit to removing.
- I work in the office Mon - Fri so I am not home to monitor the pool most of the time when the pump is running. On the weekends towards the end of the season, I noticed that occasionally the controller would indicate Low Salt. So I’d take a sample of pool water and test with Taylor K-1766 kit and salt was fine (approx. 3800). An hour or so later I’d go outside and the Low Salt indicator would be off. Does this sound normal? If I change the controller display to show the Salinity, the value is not stable and goes up & down as I watch it so thinking it’s just not an accurate measurement and I can ignore this & trust my Taylor kit results.
- As noted above, I am often not home with the SWG & pump are running, so I cannot always see any indicators from the controller as they show up (like the Maintenance light). Is the worst-case scenario that my SWG is not generating salt, or is there a condition that could lead to damage and failure? In other words, if I’m not able to regularly observe the controller, am I potentially missing a dangerous indicator that could damage the system, or is the only possible result that I come home to low FC? If it’s the latter, I assume by regularly monitoring my FC levels I can remain apprised of any issues. I just don’t want to miss a looming problem but I can’t be there every day to look.
- Is scaling on the plates obvious? Is there harm in cleaning it each winter just to be safe?
