I've got a hose bib about 10 feet from my equipment pad. I'd like to add a connection to add fill water into the plumbing at the pad. I'm pretty sure a setup like this has been done before, but I haven't found the details in the searches I ran... I've found more information about auto-fill systems, which isn't what I'm looking for. I want a hard-plumbed system that I can control via my Intellicenter or another convenient and reliable system.
Here's what I'm thinking:
The biggest questions I have are:
- Hose splitter on the bib.
- Short hose, likely a small braided steel appliance hose, i.e. washing machine hose?
- 3/4" PVC towards the equipment pad.
- A 24VAC sprinkler/irrigation valve.
- Connect the Sprinkler valve to one of the valve control connections on my Intellicenter?
- A Pressure Vacuum Breaker valve, i.e. Zurn 34-720A. Zurn 34-720A Wilkins Pressure Vacuum Breaker 3/4-Inch Assembly: Amazon.com: Industrial & Scientific
- Tee into the pool plumbing after the filter.
- Is this all the hardware I need? Do I need a check valve or any other components on the supply line, or is the Pressure Vacuum Breaker all I need, given that I'd have pool pump pressure potentially pushing water into the house plumbing.
- I'm not that familiar with pool valves and how a controller runs them. Can I connect an irrigation valve to the Intellicenter? Or should I look at using one of the AUX circuits to control a relay and operate this valve?
