I was out spraying the weeds around my pool pad and I noticed something strange - the PVC pipe from my Spa Heater looks to be melted.
This Heater was just installed (self install) at the beginning of the year and has only been run twice (setup and testing).
I don't see anything in the manual that would indicate my pipes are too close to the heater. I could move the heater to increase the space between pipes and heater but that would mean having gas company out and redo the gas line.
Maybe I need to switch to CPVC from header to where pipes enter ground.
Maybe that deformed pipe is not schedule 40 (I got a couple of pre-cut 2" pieces from the rack at Lowes where it was listed as "Schedule40 pipe". But the pipe is marked "DWV" (Drain-Waste-Vent) which I always thought was thinner than S40 - so I specifically asked the store manger to confirm - and he said it is schedule 40. Or, possibly the deformed pipe is something else that someone just tossed in the bin with the S40 pipe. I don't know.
Any ideas? I can't think of anything else that would cause that deformation besides heat. But there should not be any heat in that location. The exhaust is on the top.
