Just need some clarification on which I should use. Doing some research and it's between the Weld-on 711 or the Weld-on 795. The website says that the 711 is the strongest, but the 795 should be used on pipe underground. This is the site I am referring to PVC Glue & Primer For Swimming Pool Plumbing. Just wondering if it is a huge deal if I use the 711? Thanks
