I've had a pool guy open and close my pool every year until now. Unfortunately I never paid attention to how these pipes were connected during the summer. Is this common and how should I reconnect these?
compression coupling
No apology necessary. I agree it's a bit janky. At a minimum the cuts should have been straighter.I apologize. I wasn't serious when I referred to it as vandalism. It's just hard to believe a professional would cut pipes in order to winterize a pool. As Richard mentioned, there are unions on each of the pipes he cut that could have been detached instead. Maybe you can talk to the pool guy and get the full story. Good luck.
I've called and texted this week and unfortunately haven't heard back. I'm under the impression that a lot of his business was larger public pools so I'm not sure how the pandemic has affected his business. Maybe he was ****** at me for some reason. LOL ?The heater cuts almost look like they cut half and broke them off?
Can you email him if you split on good terms?
I think I'll end up doing this. If I had to get new connectors for the pump, filter, and heater at some point can those be found at Home Depot by chance or will I have to go to a pool supply store or website? Also, will I have to get different plugs or will I be able to use the black rubber ones again? I want to start planning for the closing now.I'm not a plumber, but I don't think compression fittings are a good idea, nor necessary. Have you ever done any PVC sprinkler work. You need three Sch 40 PVC Couplers, some Primer and Glue, and a saw. Remove the cut pipe at the unions, trim the cut ends to length to accommodate the extra length of the coupler, and glue away. Dry fitting is tough with 2" PVC, so make sure your measurements are accurate. You may need a Strap Wrench to help loosen the unions at the pump and heater. In a pinch, an oil filter wrench may work on the unions. Hopefully the unions weren't installed with glue on the threads. If so, it would explain why he cut the pipes.
Thanks again. I was able to rig up a set up to vac to waste today. I'll glue up the pipes tomorrow and work on redoing the pipes this summer, maybe with a diverter, to make it easier to open and close going forward.The unions for the pump and heater are most likely proprietary. Instead of using couplers linked in my post, you can use the type shown in Richard's post. These are generic unions you can find at HD or Lowes. You can separate the pipes at the unions when closing times comes. Richard mentioned the potential need for new o-rings for pump/heater unions.Save the winterizing plugs...you should be able to use them.
