Putting up an Intex XTR 32x16 x 52" saltwater system pool soon. Hello all.
astonerii
2
nc
I am preparing my back yard right now to put up the above pool and came here to see if there is an idiots guide to doing this that includes all the information in a single post.
I have landscapers currently leveling a 42 x 24 foot part of my backyard. It required about 2 feet of depth at the house side of the area. I am having retaining wall put all around this area and filling with 4 inches of crushed gravel with a layer of landscaping cloth and then 2 inches of rounded pea gravel. I plan to buy one of those under the pool liners to put on top of the pea gravel. Are there any recommendations on brand that is best? I was looking at Rhino, it is said to be 1/8 inch thick...
I was planning to get the INTEX 26377EH Ultra XTR with saltwater system but reading the forums, it sounds like the filter system is not really big enough to really keep the pool clean? If this is the case, saving several hundred on the pool might be better to get the INTEX 26373EH Ultra XTR and spend the extra money on a different pump/filter/saltwater generator system?
If I end up needing to replace the filter system, what pump/filter/saltwater system setup is preferable?
I have read about ozone generators built into one of the intex saltwater systems, is ozone a good fit with saltwater systems or is it meaningless or detrimental to saltwater? I have read that it destroys chlorine but have not actually found any authoritative statements on this.
I plan to add a heater/chiller to the pool if we end up deciding that having a pool long term is what we want. It will likely be about 140,000 BTU. So, the pump/filter/saltwater system should be compatible with a heater/chiller of this size.
I have read that an above ground pool needs to be both grounded and bonded. I am unfamiliar with what bonding is. Grounding should be doable with a rod driven into the ground. What does bonding require? Does it have to happen before the pool is fully assembled?
Also, the side supports of the pool need to be supported, supposedly some kind of 2 x 12 or something and I have seen people discuss using paving stones such as 16 x 16 x 1-1/2 thick. Would these paving stones work ok with a crushed stone base? Some commenters discussed them breaking and I read one recommend reinforced ones. I have never seen reinforced ones online. Are these home made or something? Does someone have a recommendation for supports? If we keep the pool long term, I think we would want to leave it up overwinter. We have mostly mild winters here, no snow most years. So I would want what ever supports I use to last at least 3 years and preferably 5.
Is the pool cover easy to put on and off and if I leave it tied to one side of the pool does that make it easier?
Sorry for all the questions. It just looks like this is going to be a pretty heavy lift for me, and I want to go in prepared as I doubt my body would be able to put this up, be forced to take it down and then be capable of putting it back up again in short order.
Welcome to TFP! :wave: Some answers for you:
- Rhino pad should work. Others have used Gorilla pads or insulation panels.
- While some people do upgrade to a larger pump & filter from the stock/factory set, it's mainly to help with water circulation and future upgrades like maybe a fountain, wide mouth skimmer, or additional return jets. Keeping the water clean is all about proper water chemistry. You MUST test and maintain your water with a TF-100 or Taylor K-2006C test kit. If you don't, you'll be back her one day asking why your water is cloudy or green. See more at our Pool Care Basics page.
- Ozone is not needed. The sun's UV will take care of all your oxidizing needs to remove combined chlorines.
- See the link below about bonding.
- For pavers, just a standard paver block. Always best to ensure it's on a well-leveled and firm base to avoid it snapping later. Some people look for the thicker pavers as oppose to the standard thickness. Others elect to use planks cut from a 2x10 or 2x12 board.
Thanks. Lots of useful information.
Wow, that bonding thing seems complicated. If I can get away with just using the Intex filter set up, it seems that I will not need to do any bonding of the pool as it comes with the ground fault built into it and the pool itself offers no bonding mechanism.
If I go with a different pump/filter/saltwater generator, that may be needed.
Fortunately, I own a fish tank and am familiar with running water tests. So that should be the easy learning curve...
Reactions: Texas Splash
Hello astonerii, I am new here as well putting up the exact same pool, how did yours turn out? any issues or anything you faced yet? i am about to start filling mine tomorrow 8-1-2023 so I am pretty nervous, I am afraid i may have done something not correct and it will end in catastrophe, Maybe it's just the nervous nelly in me, lol But good luck with yours and i hope it all turned out well for you
Casper27292... I just signed up today and we are also getting ready to install 16x32 Intex. I notice on your pic you have one support with a narrow concrete block, is that by design and what is the reason for one narrow support? We need all the info and help we can get. Your pool is looking good.
Everyone, please note that the top of your support blocks should be level with the ground, or if you are using form boards, level with the foam.
Boys, I think the likely explanation for the narrower block is that he ran out of the larger ones! But your blocks should be wide enough for the whole U shape to fit onto, otherwise the weight of the water could cause the U to bend in the middle.
