My pool heater has worked fairly well for the 11 years that I've owned it, but now I can't get it to stay lit.
Background: The heater came with the house/pool when I bought it out of foreclosure in 2012. I don't know any history on it before that, but it is old. In 2013 I wasn't getting enough voltage from the thermopile, so I replaced it and that took care of that problem. I also replaced the pressure switch in 2015.
The heater has worked fine until a month or so ago. I couldn't get the heater to fire up. I checked voltage, and was only getting about 190 millivolts. While trying to remove the thermopile, I accidently broke the pilot assembly. So I bought a new thermopile and pilot assembly. I am now able to get about 500 millivolts from the thermopile. But when I flip the switch to on (spa or pool), the furnace starts to fire and then goes out, and then the pilot is really weak looking. Below is a link showing what happens.
You can hear me flip the switch on at the 2 second mark. Then it begins to fire at the 13 second mark, but then immediately goes out.
Does anyone have any ideas on what the problem might be with the heater?
Cody
Cody
