A couple of days ago I noticed one of the returns was blowing a lot of bubbles. I walked over to the pumped and it is surging to the point of vibration. I can see the water coming through at far too high a rate.
The return in the spa is also too powerful, to the point the overflow is splashing.
I did install a new salt cell a few weeks back but the issue only started a few days ago.
After some reading I've determined air is getting into the pump somehow. I let the air out of the pump, it hissed for a much shorter time than usual which was wierd, then I let it run until water came out to create the vacuum. Still had the issue.
I checked for leaks and there was a small drip from the salt cell manifold so I got new o-rings, lubed them and put them in. There doesn't seem to be any other leaks now. If there is a leak it's too small to find so I'm not sure it's big enough to cause this surge.
It's still surging away and I'm really not sure of next steps. Any ideas?
