So this isn’t actually my pool pump, but rather a pump for my shallow well. Someone told me that it was very similar to a pool pump, so I’m hoping that someone here might be able to help me. I know very little about the pump as it came with the house when I bought it 6 years ago, so the pump is at least 6 years old and probably a good bit older than that.
However, the motor (or something) seems to be failing. When the pump is turned on it doesn’t spin and the motor just hums/buzzes. This actually happened a little less than a year ago and I had someone come out and he said that he replaced the starter capacitor and tried to spin the shaft to make sure it was free and that fixed it at the time. But now it seems to have the same problem. I tried replacing the starter capacitor again, but that didn’t make a difference this time. I’m not sure what he did to try to turn the shaft though, so I didn’t try that.
So at this point I’m not sure what the best option is. I’m not sure if there’s anything I can do to get it working again or if I can just replace the motor or if I would be better off replacing the whole pump. It’s also worth noting that the pump has leaked for pretty much the entire 6 years that I’ve had it. When the pump runs water drips out of the bottom where the metal band goes around it. Since it only runs for a couple of hours a couple of times a week I’ve just never really worried about the leak.
As you can see below, the label has completely faded from the sun, so I really don’t know what brand this is or much of anything about it. I looked very closely at the label and believe that I can make out that it was a 2HP motor and I know that it runs on 220V, so I guess that’s something.
Thanks for any suggestions
