Pump for Easy Set 650 gallon pool
If you want to keep it simple, I'd stick with a basic Intex cartridge filter pump like this:
Available at Walmart.com for $86.87.
Two to three times the flow rate of your current pump. Plug and play. Get an extra filter and change at least daily while you're working to get your water clear, cleaning one while the other is working. Once things are cleared up you can probably swap weekly.
