Thanks for the replies. I know that many people do not bother with bonding the pool or pump due to the temporary nature of the pool, plus the fact that there is GFCI protection on the pumps.
What I am wanting to do is run the pump while the pool is occupied at times, as I am going to be adding water features, like the LED waterfall, which becomes pointless if the pump is off while people are swimming. I have read the manual for the 16in Intex pumps, and they do not require them to be turned off while the pool is occupied, as other pumps do. I was just thinking if I plan to run the pump for water features, perhaps I needed to bond the pool, and the pool water as well.
Those are my thoughts.
I have run all my intex pools while in use. Not doing so has the logic of unplugging your hot water heater before showering in my opinion.
There is no explanation for that recommendation in the manual - whether it be for entrapment prevention purposes (such as hair in the intake) or electrical safety reasons. Obviously it is to obsolve them from some liability. Keep in mind these same people make a storable/temporary hot tub that doesn’t have the “un plug
it” warning. This is possibly because the manual specifically forbids children to use the product (although anyone could become entrapped)
Your risk tolerance may vary on the subject.
All my temporary intex style pools have not been bonded.
They have been gfci protected (which trips when a small imbalance between neutral & hot occurs)
& were also fed by a functioning properly sized over current device (breaker) with a proper equipment grounding conductor so a trip would occur in the event of an over current or dead short.
The pumps were also all double insulated. (This also excludes the pump from bonding requirements)
Grounding & bonding are two different things.
Bonding simply makes everything the same potential- in the water & around the pool. It does not provide a path to ground. It is intended for protection from stray currents - whether they may come from the environment or your isolated pool equipment (which as stated above has 3 systems in place to prevent electric shock). All This is not to say that you shouldn’t bond your temporary pool to protect yourself in & around the pool from stray currents if you wish, but merely to explain why it is not required.
You can bond the frame of the pool, the water, & metal ladder if you wish but bonding the intex pump is a different matter as it has no bonding lug & is encased in plastic requiring you to possibly take it apart to accomplish this task as they are not designed to be bonded (unless new models have changed). If you wish to bond the pump you may want to get a regular permanent above ground pool pump which comes with a dedicated bonding lug. If you decide to go ahead & bond your temporary pool but are still going to use the intex pump you can still run the piece for the pump but just not connect it so it’s there for the future if you upgrade your pump to one that is not double insulated.
