I am currently having a pool built and they are installing a spillover spa. The spa will stick out of the ground about 12".
I have been getting some conflicting information on how this is supposed to be winterized, and its different for a spa that is elevated vs level with the ground.
Should they be plugging all the drains and jets before they fill it since its winter here now?
I assume that you would have to unscrew each drain cover and put a plug in and the same for the jets?
Thanks in advance.
Thanks in advance.
