Tanner,
Filter pressure is not a function of how well the pump is doing.. It is how much effort it takes to push water through the filter.. As long as you have good flow, then the lower the filter pressure, the better..
I have a 3 HP IntelliFlo and a CCP 520 cartridge filter. I have a 30 lb, gauge. When running at 1200 RPM, my filter pressure is about 1 lb.
I have never run at 3450 RPM, as it is just not necessary with my pool.
The whole point of having a VS pump is to run as slow as you can and still get the job done. Most of the time I run about 1200 RPM.. This speed turns on my SWCG and makes my skimmers work well. I have no spa or heater so I only run faster when I want my waterfall to work (Not often) and when I want the water in the pool to swirl a little more if we are using our floats.
I run 24/7 for less than $20 bucks a month.
When you say 'jets' are you talkin about spa jets or your pool returns? If your pool returns, the size of the eyeball has a lot to do with how much 'pressure' you feel. The larger the eyeball, the less pressure.. Smaller eyeballs will also increase your filter pressure.
Show us a couple of pics of your equipment pad.
I would think that at 3450, you would have more filter pressure than 10 lbs.. I suspect that your gauge is bad or maybe the port between the gauge and the filter body is partially plugged.
