Will be receiving and setting up my Intex Prism Frame Pool next week. Will be an all-around-year setup. Plan is to build a high-deck around it.
Not knowing much about pools, I ordered a Saltwater system, but then found out that Intex Frame pools can have problems with rust, some only after 1-2 years. I would really hate to have to take down the pool and replace it after a short while, especially since I will be building the deck around it.
So was thinking about solutions/ideas to pre-protect it before adding the salt. It seems most rust cases I have read about have problems with the corners, not so much the legs. But overall the problem seems to be related to all the metal parts, that are free/visible and not covered with the lining (Which of course make kind of sense)
I was thinking about first covering those parts (legs and corner frames) with some kind of rust-protector before assembly, But also finding something plastic, like e.g. pump hose that could fit around the frame like a cover to protect that further. I know would not look good, but does not matter in my case, as I would have a wooden deck to the top of the pool, so legs etc would not be visible.
Have anyone tried to do something like this pre-setup? and if so, do you have any better ideas? I have read a lot of posts about rust, but they seem to be mostly about action needed after the problem has happened.
