Pool stain in deep end that won't go away (now confirmed iron!)
kstough
Active member
Jun 7, 2019
43
Ozark, AL
Update: thanks to @mguzzy I have confirmed the spots are iron stains. What is the best/easiest/cheapest way to get rid of this small area of stain that’s around 6x4’? Will I need to wait to treat until after SLAM is complete? Will the stain come back next time I need to SLAM (I read on here that it can)?
We had algae/pollen all over bottom of pool when we took off our safety cover a couple weeks ago. We scrubbed and vacuumed but there is one area that the stain has not come up. I've tried putting a chlorine puck on it for several minutes and feel like it didn't make much of a difference. We are currently on day 4 of SLAMMING the pool so I would have thought the higher chlorine levels would have lightened the stain. We didn't have any metal items in the pool that lead me to think it could be an iron stain. The weird thing is that when we removed the pool cover the area that is still stained was one of the least soiled areas in the pool. My fear is that is is somehow on the other side of the liner....possibilities?
TFP Test Kit Results:
FC 12.5
CC 0.5
CYA 30 (not TFP—result from store)
TA 70
PH 7.5 (before SLAM)
Salt 3000
What to do?Screen Shot 2021-04-26 at 9.38.44 PM.pngScreen Shot 2021-04-26 at 9.39.03 PM.pngScreen Shot 2021-04-26 at 9.39.14 PM.pngScreen Shot 2021-04-26 at 9.39.27 PM.png
You've made fantastic progress in 4 days! I'm not an expert but I'm sure one will be here soon to help you. Until then, continue with slam.
What kind of filter do you have?
Reactions: kstough
The only algaecide we used up to that point is Regal algaecide and it said “A non-foaming, non-metallic 60% strength polyquat algaecide.” Wouldn’t that mean it doesn’t contain copper?
Yes as it says "non-metallic". Polyquat 60 types are the only ones we ever suggest using, and they're more a preventative helper rather than a algae killer.
Maddie :flower:
I passed the OCLT last night! What a great feeling. I’m going to keep higher SLAM FC levels today just for good measure and then let my FC levels drift back down and get my CYA up to 60.
Now time to buy and crush up a lot of vit c tablets for those iron stains...
  • Love
Reactions: Snoobug
I don't think you are going to be able to do just a localized cleaning and have the stains removed permanently .. the iron is in the water and you really need to deal with it at the level of the whole pool. The staining is the sign that tells you that there is Iron in the water at a high enough concentration to cause stains. So I think you should prepare yourself to treat the whole pool and here's why. Ascorbic Acid (vitamin C or AA as we refer to it around here) will remove the stains from the vinyl and other surfaces, but it only changes the iron to another form so it will go into the water. Eventually it will change its form back and restain unless the iron is removed from the water. (I'm really trying to not dredge up high school chemistry, its painful for some;)). You can
1) Use AA on the entire pool to remove stains from the surfaces then drain and refill with iron free water
2) Use AA to remove the stains and then use a sequestrant that will bind with the Iron in the water...eventually you will have do it again, because the sequestrants will break down and the iron is released. Some people do an AA treatment followed by the sequestrant followed by a drain and refill to be assured of getting it all.
3) Use AA and then use a sequestrant that can be filtered out.. and to my knowledge there is only one product that will do that called Metal Magic.
4) Get the iron to go into the green form (your water turns green) and then setup a polyfil filter to filter the Iron out.
Then afterward you need to figure out where the iron is coming from. If you are on a well its likely in your fill water and you can set up a filter for that, or I have seen owners set up cistern systems that allow them to use rain water to refill their pools.
Let me send you down these rabbit holes for your information on how these work.
Here is my recent-ongoing thread on treating Iron:
And another one:
The often referenced polyfill filter thread:
Good luck!🍀
Reactions: Snoobug
I use vitamin C tabs all the time for iron stains .. just be careful because the vitamin C can eat up your chlorine! Make sure you are testing FC regularly while using the vitamin C.
I just went through this last week and mguzzy was spot on. Went from brown staining to a perfectly blue liner in a day.
It wasn't terribly expensive. 4 bottles of Robelle's mineral out sequestrant were the most expensive part ($40 total), and 5 lbs of citric acid ($20) along with a $5 bag of polyfill was all that it cost me outside of the normal rebalancing chemicals (which most of us have on hand anyhow). I didn't think my pool light or my entry steps were stained but wow at the difference afterwards. I'd recommend treating the entire pool and not just the spot. You will likely be surprised at what all might be stained.
