Dear gurus - I'm stumped and could use some input. What I want to solve for is a spa that can be maintained at temperature. Currently with the P/S combo scenario the way it's set up, pool water is circulating through the spa all day such that the spa is always at pool temp (ie. not hot).
Caveat that I don't know much at all but am grateful to this forum to the little I've gleaned. So, please feel free to ask me clarifying questions, let me know what additional information I can provide as input, or for that matter maybe I'm asking the wrong question altogether! Thank you in advance.
The system had been running as a P/S combo on Jandy automation. I'm changing to Pentair Intellicenter and don't know if I need/want the i10D or i10PS. Note, it is a salt water system if that matters.
We have a pool with elevated attached spa that can spill into the pool. I believe the way it was running previously was with one VSP running the pool and infloor cleaning most of the day. When we wanted to use the spa, I believe an actuator redirected the pump function to the spa. I do know that during the day when it was in pool cleaning mode, there were times the spa would overflow into the pool. There's just one heater, one filter. BUT, we have a second VSP that I believe kicked in for just spa mode for extra jets. And in reality we only use the gas heater for the spa. The pool draws solar rooftop heat all day.
We're completely open to changing up the design, perhaps dedicating the gas heater to the spa only to keep it at temp but also some configuration where the spa is getting enough filtration and SW chlorine generation. Suggestions on how I might accomplish this? Must it be managed as dual bodies of water or can it be done as a P/S combo?
