Hi all,
When using the spa, the pool water would slowly drop down after about 45 min maybe an hour. I have done some research and most videos say you need to change the valve or close it off to only draw water from the spa. Which I was not aware of. We bought the house with the pool and our pool is slowly growing. I am unsure which valve or valves needs to be adjusted. Grateful if you could shed some light on the correct valves. Please see attached photos.
Thanking you in advance
