Pool, Spa and sheer decent water feature - 1 or 2 pumps
tjk65
64
Round Rock, Tx
Hi all,
I am trying to compare pool bids which the PB's make extremely hard to do. However, I got 4 bids and only 1 pool builder has quoted two pumps. All have included a 3HP VS Pentair Intelliflo. The one with 2 has two of these. Seems strange that I would need the same size pump for the pool and spa. We are looking at pools design that are 85-90 in perimeter and 22 perimeter spa (6.6ft round) with a water feature wall with 1-3 sheers. What questions do I need to consider for 1 or 2 pumps and if two is the right way to go, should the be the same size? We are also having the Pentair 520 cartridge filter quoted and plan on going with a SWG, which no one has included in their quote. I want to make sure I get the equipment right. What should I be asking for? Newbie to pools and looking for ease of care. Also have a question on auto fill? Pool Miester seesm really expensive and we have been told we could have plumbed and have our sprinkler guy hook up a zone to auotfill. Is that a bad idea or a good way to save $$?
You will need to be much more precise than "1-3 sheers" as the quantity/length is very important to the calculations. As an example, there is a very big difference between 1 sheer that is 12" long and 3 sheers that are 36" long each (the former needs approximately 12 gallons per minute while the latter needs approximately 108 gallons per minute). I can try to help you out with the thought process if you specify the following:
Number and size of water sheers.
Height of water sheers above water.
Any other water features you will have.
How far from the equipment pad to the pool.
Do you want to run anything besides the sheers at the same time (like pool returns or spa)?
I was told that we wouldn't need a separate pump for water features unless we wanted to be able to use water features at the same time as we were using soa mode. My response to the builder was that I would check with the wife but we likely wouldn't need to be able to run everything all at once. I was wrong, she wants to have the ability to have the sheer descents and bubbler while in the spa. For our setup we are adding a water feature pump that is not VS and isn't as big as the primary pool pump ($785). I told the builder that when he does the plumbing I want the ability to run water features from either pump and will only use the second pump while in spa mode. Not 100% sure if you will gain much with the second VS pump, but I'm interested to hear what everyone has to say.
Like Sparks mentions, really need more information for your setup there, TJK.
I have 2, Pentair 3HP VS pumps. One running my water features and one running the pool/spa(filter). Originally my PB set up one of the water features on the pool pump, and it irritated me because I couldn't use that feature when the spa was on. So I reworked my plumbing to put all three features, bubblers, deck jets, and scuppers, on the one pump. So lesson there is make sure you go over the plumbing with the PB ahead of time so that everything will work the way you want it to.
Regarding the autofill, I have the pool miser. Not sure what that cost because my PB puts them in standard. I suppose you could have a line ran to your pool that your irrigation could tie to, but you would have to manually turn it on/off, and it wouldn't have an overflow line like the pool miser has. I love having the autofill. Wouldn't trade it.
SPD, regarding your comment, I would not try to plumb so that either pump can run the features. I think that would add unnecessary complication to the plumbing, as well I think it will take up a ton more real estate around the equipment pad. Plus, I'm not sure the automation can handle that configuration. Without seeing a plumbing one line diagram, it is hard to determine how it might be automated. I prefer the VS pump on the features. I run my features pump @ 1500rpm max. That is if the deck jets are on. Otherwise it is usually @ 1200rpm. For me the VS is perfect because my equipment pad is within earshot and running that low, I have no noise from the pump.
--Jeff
You have a good point, I will review the plans with the builder to make sure we are doing what will be the best configuration. Thank you for your input
Ok we are finally in the home stretch. We have 3 sheers 24 inches. 2 at 12 inches above water and 1 at 18 inches above water. We have a bubbler on the sun shelf and spillover on the spa. Equip pad about 30-40ft. Yes want to run together or independent.
Equip they ordered:
Pentair 1 1/2 hp Pump Whisperflo Hi Perform
11773​
Pentair 3HP 230 Intelliflo VSF
11056​
2HP Blower
6320241​
420 SF Cartridge clean and clear
16031​
400K BTU Mastertemp
460736​
EasyTouch 8SC-IC40 - Pool/Spa
520545​
Intellibrite
601012​
40K GAL Intellichlor IC 40
520555​
