Hi folks, I'm new to TFP and currently redoing my pool. Main changes are that I'm extending the steps and adding two benches in the deep end. This is what it looks like with the new steps in progress:
And here are the two corner benches:
I have a couple of questions:
1) The lines going down the wall due to the demolition of the plaster -- is this normal? Does it have to be smoothed out before applying the new surface?
2) Is it normal to use cinderblocks to "frame" steps/benches as is being done here? The empty space behind the steps is filled with debris -- old plaster that was chipped away, extra concrete from the demolition of the existing steps, etc. Want to understand if this will hold up over time.
This is my first time renovating a pool so want to make sure everything is going well...
