Pool pvc cement
Deb Driesen
65
FINGER LAKES NY
Fiberglass
Hi guys,
Is there a special kind of pvc cement for pool plumbing? I heard it is more resistant to chlorine and salt. If it exists, and if it's recommended, what is it called?
Thanks in advance.
Deb
while there could be pool-specific PVC cement out there, I’ve nit heard of anyone using anything other than the normal stuff on the shelf at HD/Lowe’s, etc. as long as you use cleaner, primer, then cement, and as long as you let it cure as it should, you’ll be just fine.
