Pool pump support base
miamicuse
128
Fort Lauderdale, Florida
I recently inherited an older pool pump that is still working, and I am considering using it as a pump for my koi pond or as a backup pool pump.
The problem is there is no base for the pump.
I believe it is called a Sta-Rite Dyna-Glas/Dyna-Max series, I think it is a C76-58P, on the motor housing it says MOD C48K2PA105C5 SER 23714CH.
What kind of a base will fit this? Base on my search I think, but not sure, I need a Pentair C4-42P, can someone confirm?
if you were in the country in podunk Georgia, it would be sitting up on a couple of bricks. :laughblue:
If you call INYOpools they may have the actual base or an equivalent for your needs. They often have the hard to find parts.
Maddie :flower:
The issue is I don't really know for certain what kind of pump I have. Here is a picture of the pump.
But the stand under it I don't think it's the right one.
The pump housing has no label on it. there is a label on the motor, but my understanding is the motor may not be the one originally paired with the housing right?
Motor says USQ1102 MOD. C48K2PA104C5.
The current base it has does not sit right. The housing has to be an inch higher than the motor for it to sit right, even then the base was modified with some cuts, to get it to kind of work. The current stand says C4-42P but again I think this is not the correct stand.
Any idea what this pump is and what stand fits it?
Or I need some bricks?
Pentair C4-42P Motor Base Replacement Sta-Rite PLBC Series Pool and Spa Pump
The base is incorrect for the pump. The base goes to the following.
I think that the pump is the following.
I think that the stand would be the following.
@JamesW and @YippeeSkippy thank you both for the assist!
C4-77P is indeed the correct base for my pump. I found a used one on ebay and already bought, received and verified that it fits!
I think what got me confused with the existing C4-42P - I kind of knew it was not the right one, but the last owner used it under it and used bricks to level it...and when I put the C4-42P at the bottom, there are two bolt holes on the top of the plastic saddle that align perfectly with the two bottom bolts of the seal plate to the tank body which made me wonder if it may be the right base with missing parts.
Thank you for the help!
