I’m having difficulties getting my pool pump to prime. It’s a single-speed Waterway motor for my in-ground pool. Following a vacation and subsequent algae bloom, my pump became difficult to prime.
I performed the following troubleshooting steps:
-Cleaned cartridge filter w/ hose and acid/degreaser bath
-unclogged impeller
-checked water level at skimmer, skimmer basket and pump basket for anomalies
-used bladder hose at skimmer, on pump intakes to check for clogs in pool line
-inspected and lubricated o-ring on motor cover
-applied plumbers tape to pump housing drain plug
-ran water over drain plug, motor cover, all unions, joints and jandy valves
My pump has never had difficulties priming and always fills pump housing with no cavitation. Return jets are weak so something is definitely off.
Any advice?
-unclogged impeller
Any advice?
