So you get a call to a pool that has the following:
CYA: 0
TA: 30
pH: 8.0
TC: 0
FC: 0
CH:250
Temp: 65 f - 78 f each day
The water is teal green and hazy, looks like the chlorine has recently been depleted due to still being able to see all the leaves on the bottom
It takes the client 12 days to agree to your quote + 3 more days before you can start on it due to xmas/new years. So now you return and its now a darker green, you can only see the floor on the 3' shallow side
. You remove enough leaves in it to fill 1 x 55 gallon drum.
C = Circulation is Good, C = Cleaning out all debris completed, C = Chemicals / CYA, Acid, TA, SLAM completed - Flocc'ing is a must due to all the dead algae, using powder shock and the client wanting the pool finished within 7 days.
PS. I told them I don't do yard work and they need the yard cleaned before I flocc the pool (see pics)
I have used both, and both work well, but I prefer Alum when lots of powders are used to clean a green pool. With Alum it does take 3-4 days to be ready to vacuum, which is not a problem and the water looks like its been filtered when done
I am thinking of trying 2 bottles of Regal QT SUPER FLOC this time instead of powder alum, what do you think?
So what do you prefer and why? - Alum Powder vs. Liquid Floc
Price is not a factor, but here is what we pay in South Texas
10lb of Alum = $14.53
REGAL QT SUPER FLOC = $6.49
Thanks in Advance
CYA: 0
TA: 30
pH: 8.0
TC: 0
FC: 0
CH:250
Thanks in Advance
