I was hoping someone might be able to assist me with a new issue I am having with my pool and spa light which I noticed last night weren't working.
I have a Pentair Easy Touch along with white led lights for the pool and spa which are only a few years old.
I notice the red light goes on when I hit Aux2 on the Easy Touch and it shows on in the Pentair App. I can even hear it click on and off on the app panel when I toggle it in the app. I checked the gfi and electrical panel and both look good. Even tried resetting the breaker.
I did notice that when I turn on the lights for the pool the green light turns on the the gfi and when I turn off the lights the green light goes off. Theres nothing plugged into that outlet. Not sure if that is normal for the gfi for the light to go on and off? I did try plugging in a light into the outlet and it worked.
Not sure what my might be?
The only thing that has changed recently is a contractor doing some other work on the main electrical panel. Not sure how he could have done anything that would affect the lights?
Everything else works fine, pump, spa, heater etc. just the lights are no longer working.
Any help would be appreciated.
Thank you
Thank you
